averagejohndoh
Jan 11, 2021Follower
routerlogin.net edge browser
I cannot login to routerlogin.net. I only have edge browser and they do not allow http. They require https. So when I put in the username and password it just keeps refreshing the page asking me to p...
antinode
Mar 16, 2021Guru
> [...] I only have edge browser and they do not allow http. [...]
"do not allow" or "complain about"?
It's common to get complaints from a modern web browser when you use
the router's/extender's management web site, because the browser is
worried about your sending some user credentials over an
unencrypted/insecure link ("http://" instead of "https://"). The easy
thing to do is ignore the warning, and proceed. Presumably, you're
talking to your own gizmo on your own LAN. If someone can overlisten to
that local traffic, then you're already in big trouble.
Worst case: Use a more cooperative web browser.
- wcalifasMar 16, 2021Prodigy
Try www.routerlogin.net or 192.168.1.1
- antinodeMar 17, 2021Guru
> Try www.routerlogin.net [...]
Have you any reason (evidence, plausible grounds for speculation,
anything at all) to believe that "routerlogin.net" and
"www.routerlogin.net" would be resolved differently?> [...] or 192.168.1.1
Or that specifying an address instead of a name would affect an
"HTTP" v. "HTTPS" difficulty?- wcalifasMar 17, 2021ProdigyLol antinode stop talking with gibberish, speak clearly instead of asking dumb questions.
