Shortstop
Dec 11, 2015Tutor
routerlogin.net on R6100
I connected the R6100 router to computer "A" and I negleted to run "routerlogin.net" before I connected computer "B" to the router. I wanted Computer "a" to be able to run the setup and all the admi...
- Dec 11, 2015
Thanks for all the information from everyone. I ended up calling tech support. Computer "A" will not login using the "routerlogin.net" but has to use the computer's IP address to login. Anyways the problem has been solved.
TheEther
Dec 11, 2015Guru
It sounds like computer "A" is either not properly connected to the router or is not properly configured. Can it access the Internet?
Do you know the router's IP address? If so, try entering it into computer "A"'s browser. If you don't know the address, you can get it by logging into the router from computer "B". The address will probably be 192.168.1.1 or 10.0.0.1.
Shortstop
Dec 11, 2015Tutor
