porkchopbruno
Aug 08, 2021Aspirant
routerlogin.net
Trying to connect my Nintendo Switch to Netgear wifi router, but the router's settings did not allow me to connect my swtich. I was initially able to access the routerlogin.net /192.168.1.1 and chang...
Aug 08, 2021Guru - Experienced User
What settings would not save?
What exactly where you changing?
What router do you have?
Why wouldn't the "router's settings' not let the switch connect?
Worse case scenario, factory reset the router and start back at factor. Push and hold reset for 7-15 seconds while its powered on.
then reinstall it with how you'd like it setup.
