porkchopbruno
Aug 07, 2021Aspirant
routerlogin.net
Trying to connect my Nintendo Switch to Netgear wifi router, but the router's settings did not allow me to connect my swtich. I was initially able to access the routerlogin.net /192.168.1.1 and chang...
antinode
Aug 08, 2021Guru
> [...] There were two areas in the wireless settings on routerlogin.net
> that I made this change to. I clicked "apply changes" and nothing would
> be changed. [...]
Do you mean BASIC > Wireless : Security Options (for each radio), or
what?
If you did reasonable things (which I can't see), and "Apply" did
nothing, and no actual error message was emitted, then I'd suspect the
firmware.
> [...] Firmware version? [...]
Still wondering. If your firmware is current, then you might try a
settings (misnomer: "Factory") reset, and manual reconfiguration.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Reset".
> [...] I looked this up, [...]
Thanks for the helpful link(s). According to:
https://en-americas-support.nintendo.com/app/answers/detail/a_id/27644
practically anything better than "None" should work. But, if the router
fails to accept a legitimate settings change, then I'd wonder what it's
doing.
porkchopbruno
Aug 09, 2021Aspirant
The other problem is that I can't get into the access control ( https://www.routerlogin.net or https://www.routerlogin.com)
I was initially able to change the security settings of the network on those websites, but now my internet browsers will not let me access these sites. I'm getting the standard "this site can't be reached" on my Macbook.
The wifi router is 10 years old. Maybe it's time for a new one?
- antinodeAug 09, 2021Guru
> The other problem is that I can't get into the access control [...]
Regarding "can't", see "not a useful problem description [...]",
above.> [...] https://www.routerlogin.net or https://www.routerlogin.com [...]
Try "http://" instead of "https://" (as in the instructions)?
It's obsolete junk, but so is at least half my inventory. Perhaps
it's time actually to _read_ the User Manual, and not just skim over it.
