porkchopbruno
Aug 08, 2021Aspirant
routerlogin.net
Trying to connect my Nintendo Switch to Netgear wifi router, but the router's settings did not allow me to connect my swtich. I was initially able to access the routerlogin.net /192.168.1.1 and chang...
porkchopbruno
Aug 10, 2021Aspirant
The other problem is that I can't get into the access control ( https://www.routerlogin.net or https://www.routerlogin.com)
I was initially able to change the security settings of the network on those websites, but now my internet browsers will not let me access these sites. I'm getting the standard "this site can't be reached" on my Macbook.
The wifi router is 10 years old. Maybe it's time for a new one?
antinode
Aug 10, 2021Guru
> The other problem is that I can't get into the access control [...]
Regarding "can't", see "not a useful problem description [...]",
above.
> [...] https://www.routerlogin.net or https://www.routerlogin.com [...]
Try "http://" instead of "https://" (as in the instructions)?
It's obsolete junk, but so is at least half my inventory. Perhaps
it's time actually to _read_ the User Manual, and not just skim over it.
