orcslaya
Jul 24, 2021Follower
Routers that support Remote Management
Below shows the list of AC router that supports Remote management or anywhere access. I am posting this after a lot of confusion on whether the R6120 supported this feature or not (It does NOT). Hope...
michaelkenward
Jul 26, 2021Guru - Experienced User
Not quite a complete list:
Model R6050
R6100
R6200
R6220
R6230
R6250
all include "Remote Management" in their manuals.
There may be more!
It is a pity that Netgear does not provide this infomation.
- schumakuJul 26, 2021Guru - Experienced User
Every other year some new KB entries were created, for example https://kb.netgear.com/24235/How-do-I-use-remote-access-on-my-Nighthawk-router ...
- michaelkenwardJul 26, 2021Guru - Experienced User
I know all about those, but that does not answer the question I asked.
Which routers support remote management?
Netgear should create the equivalent of these:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Which NETGEAR routers support ReadyCLOUD? | Answer | NETGEAR Support
Yeah, and the text does duplicte (ideally) the "This article applies to:" .... how use***?
The implicit question on this thread by orcslaya is why a few - or specifically the R6120 - does not support the (IP port based) Remote Access. Or was the question about the feature named Anywhere Access again?
