orcslaya
Jul 24, 2021Follower
Routers that support Remote Management
Below shows the list of AC router that supports Remote management or anywhere access. I am posting this after a lot of confusion on whether the R6120 supported this feature or not (It does NOT). Hope...
schumaku
Jul 26, 2021Guru - Experienced User
michaelkenward wrote:
It is a pity that Netgear does not provide this infomation.
Every other year some new KB entries were created, for example https://kb.netgear.com/24235/How-do-I-use-remote-access-on-my-Nighthawk-router ...
michaelkenward
I know all about those, but that does not answer the question I asked.
Which routers support remote management?
Netgear should create the equivalent of these:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Which NETGEAR routers support ReadyCLOUD? | Answer | NETGEAR Support
