barbarino2000
Nov 01, 2021Follower
RS6250- what extender can I connect to it w/Ethernet?
I just learned that I can’t connect my WN2500RP range extender to my RS6250 router using Ethernet cabling. (Unsupported). What reliable Netgear extender is recommended that I can hardwire to? I don’t ...
Nov 01, 2021Guru - Experienced User
You might look at the EX7000 is you want ethernet support on the extender:
