LDOVE
Jan 23, 2017Aspirant
Samsung Bluray player cannot find Access Point for new Netgear R6300v2
Our Netgear 6300 router stopped working so we replaced it with a new Netgear 6300v2. Our Samsung Bluray player (BP-P1600) is still trying to access the old router and I am unable to change it to the...
- Jan 31, 2017
Thanks to the community for their suggestions, but the problem was the encryption setting on the router. Changed it in order to be compatible with our fairly old DVD player and now everything works!
William10a
Jan 23, 2017Master
Did you use the same ssid and passphase as the old router?
LDOVE
Jan 24, 2017Aspirant
Thanks for your response. Both are different. I did get the new router to show up as an available Access Point by removing and reinserting the Wireless LAN adapter from the back of the DVD player (to correct a typo in my original message, the model is BD-P1600), but still cannot get it to work. I have tried entering the security code in each authentication mode (Open, WEP, WPAPSK, WPA2PSK) and get a message that the network cannot be accessed. It doesn't say why, just that it cannot. Very frustrating. Would welcome any suggestions you might have about that.
