Kezzboy721's avatar
Kezzboy721
Follower
Jun 23, 2023
Samsung Tv Plus and other steaming issues
I have been using my Nighthawk router without fail. Recently I had to move and reset the router. After doing so it seems the router will not play my streaming channels. (Samsung) says it's my ISP prov...
  • plemans's avatar
    Jun 25, 2023
    What modem/gateway is the router connected to?
    Do you have IPv6 enabled?
    Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
    CloudFlare
    IPv4: 1.1.1.1 and 1.0.0.1
    IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
    GoogleDNS
    IPv4: 8.8.8.8 and 8.8.4.4
    IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
