paxlex
Aug 18, 2021Tutor
Scelta router Netger
Per necessità personale, causa seria ipersensibilità al wifi e alle onde radio, chiedevo se esiste un router Netgear senza WIFI (casa cablata a 1GB) oppure router con WIFI disabilitabile tramite inte...
Aug 18, 2021Guru - Experienced User
Most of netgears routers have the ability to disable wifi. Just not the mesh routers.
another option to check into for a router without wifi is the ubiquiti edgerouter's
paxlex
Aug 18, 2021Tutor
Thanks for the reply. Searching the internet I found a very interesting Netgear BR200 model.
