ngforumu
Apr 06, 2022Aspirant
Schedule restart of R6400
At the moment there is no easy way to schedule restarts other than an outlet timer. Has anyone been able to do this recently or could this be a request for future development? Why would I want to...
michaelkenward
Apr 06, 2022Guru - Experienced User
The R6400 is a router. Your have posted in the section given over to DSL modem/routers.
You might get more informed feedback in the section for the R6400.
ngforumu
Both good points. I voted for the scheduled restart idea and will see. Thank you both.
- michaelkenwardApr 07, 2022Guru - Experienced User
By the way, you can use the Nighthawk app to reboot a router by remote control through Anywhere Access.
Rather than a mechanical switch, maybe a programmatic approach would work.
