gregK
Jul 12, 2016Aspirant
secure wi fi connection stopped working..
N600 WNDR3400v3 Firmware Version V1.0.1.4_1.0.52 windows 10 and windows 8.1 Two day ago all of the sudden wi-fi connection stopped working during the day.. so I switched to cable that is working ...
- Jul 13, 2016
Thanks, factory reset did work... I tried it yesterday but apparently did not hold it long enough.. today I waited until it started to flash...Thanks again.
ElaineM
Jul 13, 2016NETGEAR Employee Retired
Hi gregK
Welcome to the community!
Try to delete preferred networks from your computer.
Then try to enable wireless security and make sure that you type the correct password.
gregK
Jul 13, 2016Aspirant
I am sorry, I do not think it will help.. here more info.. :
1. When security is on I can not connect from any device : win 10, win 7, Android, iPhone..
2. Even when I would chenge password.. it is not even asking for it..
3. When security is disabled then all starting to work..
Any ideas ?
Thanks
- ElaineMJul 13, 2016NETGEAR Employee Retired
Try to do a factory reset and then reconfigure to get the connection back.
