Crea
Jan 01, 2022Initiate
Security concerns--access to router info?
Router model not found on the list: AC 1750 I found a neighbor wandering around seemingly trying to pick up on anyone's unsecured wifi in our apartment complex. I logged into my router to check...
- Jan 01, 2022
first they need to be connected to the wifi which if you properly password protected, they shouldn't be able to.
(If they are good enough to crack the password, you probably wouldn't be the intended victim)
Then they would need to know/guess/hack the password to log in.
So just make sure to setup a decent wifi password and then a decent login password to the router and you should be fairly safe.
michaelkenward
Jan 02, 2022Guru - Experienced User
Probably because that is not a router.
AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
