Tamster1208
Apr 17, 2023Follower
Security Network key not working N750
I have a N750. I have never had a problem connecting a device until now. The network key on the back does not work. Help please.
Apr 17, 2023Guru - Experienced User
1. what device do you have? N750 is a speed
2. what modem/gateway is it connected to?
3. what error do you get?
4. did you change the ssid or password? You can log into the device and check it
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
