Tamster1208
Apr 17, 2023Follower
Security Network key not working N750
I have a N750. I have never had a problem connecting a device until now. The network key on the back does not work. Help please.
michaelkenward
Apr 17, 2023Guru - Experienced User
You are connecting wifi devices?
Did you set up the router?
Did you change the network key (wifi password)?
What does "not work" mean? What are you doing and what happens?
Then there are the questions from plemans
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual
Specify Basic WiFi Settings.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
