RX-78
Apr 08, 2016Aspirant
Seeking for help about UPnP issue. (PS4 Gaming GBONEXT)
To All Friends, Thank you for reading my post. My issue is, why sometimes my UPnP rules are not correctly generated. I'm a PS4 player who mainly play Gundam Battle Operation Next. Normally, fr...
- Apr 08, 2016
How do you know that they are bad rules? The game could be opening additional ports for receiving other traffic. How fast is your Internet connection? Maybe it can't handle all of the traffic required to play the game smoothly?
Anyway, you can try disabling UPnP and just go with port forwarding.
TheEther
Apr 08, 2016Guru
If UPnP is not working reliably for you, then you can set up port forwarding rules for those ports.
Note: Set NAT to Open in WAN Setup on your router.
