RX-78
Apr 08, 2016Aspirant
Seeking for help about UPnP issue. (PS4 Gaming GBONEXT)
To All Friends, Thank you for reading my post. My issue is, why sometimes my UPnP rules are not correctly generated. I'm a PS4 player who mainly play Gundam Battle Operation Next. Normally, fr...
- Apr 08, 2016
How do you know that they are bad rules? The game could be opening additional ports for receiving other traffic. How fast is your Internet connection? Maybe it can't handle all of the traffic required to play the game smoothly?
Anyway, you can try disabling UPnP and just go with port forwarding.
RX-78
Firstly, thank you so much for your answer.
However, I still have questions after reading your answer.
I`ve set UDP 9306 in post forwarding rules, meanwhile UPnP is not closed.
If UPnP goes bad, my networking still choose bad UPnP rules, not the 9306 I`ve set in post forwarding rules.
Shall I close UPnP if I wish to use post forwarding rules?
I understand that UPnP rules are automatically generated which can not been controlled.
Can I consider post forwarding rules as "fixed UPnP rules"?
If yes, then I think I shall close UPnP and own a everlasting UDP 9306 port.
TheEther
Apr 08, 2016Guru
Can you provide examples of bad UPnP rules?
UPnP is convenient because it's automatic but if it's not working for you, then turn it off and go with port forwarding.
