freeassociates
May 03, 2023Aspirant
Set up AC1750 Smart WiFi Router as print server
I know it's overkill. But I just installed an ASUS Mesh WiFi system and now have an extra AC1750 Smart WiFi Router (6400). I would like to set it up to work on the mesh network as a print server, sin...
- May 05, 2023
freeassociates wrote:
To be clear, I am looking to have this all on my main WiFi mesh network so that the R6400 is connected wirelessly.
Aha. That's a very different story from anything you have said so far.
Your original message said " Smart WiFi Router as print server". You didn't say how you wanted to connect the R6400 to the Asus router.
The easiest way is to do what I suggested, put the R6400 into AP mode and plug it into the Asus router.
What you now describe is wifi to wifi connection. That would mean putting the R6400 into wifi bridge (repeater) mode. That's a much more complicated move.
To do that, check the manual for the R6400 and read the section Set Up the Router in Bridge Mode.
It isn't easy, and might not even work with your anonymous router.
Your first message said "I would like to set it up to work on the mesh network as a print server".
Is there any reason why you can't plug the R6400 into the router? It would be there on the network for everything else. It would also be a lot easier to set up and manage.
michaelkenward
May 05, 2023Guru - Experienced User
But even though I have reset it to the factory settings twice, neither my computer’s browser nor the Nighthawk app on my phone can find it.
Every time you reset the R7800 you put it back into router mode, which means that it will clash with the ASUS router.
To get the R7800 into AP mode, connect it to a PC. Go to the browser graphical user interface (GUI) and put it into AP mode.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
Now, turn off the R7800. Get the rest of the network running with the Asus router.
Now, with the R7800 still turned off, plug it into the router. Turn on the R7800 and let it go through the set up cycle.
DO NOT RESET THE R7800.
If you want to get into its GUI, look at the Asus router and its list of attached devices. That should show you the IP address of the R7800. Feed that into the browser and you should be able to get into the GUI.
You can make life easier by fixing the IP address of the R7800, either in its settings or by reserving it on the router.
freeassociates
May 05, 2023Aspirant
In its previous life, the Netgear router WAS our WiFi network. That's why I reset it. But I didn't realize I needed to plug my computer in directly to set it up. Excellent. I'll try that. Thanks so much for your help with this.
- michaelkenwardMay 05, 2023Guru - Experienced User
If you can see, and connect to, the wifi from the R7800, even when it is in router mode, then you may also be able to access the page where you can switch it to AP mode.
But that is getting a bit complicated. Stick with the KnowledgeBase description.
