freeassociates's avatar
May 03, 2023
Set up AC1750 Smart WiFi Router as print server
I know it's overkill. But I just installed an ASUS Mesh WiFi system and now have an extra AC1750 Smart WiFi Router (6400). I would like to set it up to work on the mesh network as a print server, sin...
  • michaelkenward's avatar
    michaelkenward
    May 05, 2023
    freeassociates wrote:
    To be clear, I am looking to have this all on my main WiFi mesh network so that the R6400 is connected wirelessly.
    Aha. That's a very different story from anything you have said so far.
    Your original message said " Smart WiFi Router as print server". You didn't say how you wanted to connect the R6400 to the Asus router.
    The easiest way is to do what I suggested, put the R6400 into AP mode and plug it into the Asus router.
    What you now describe is wifi to wifi connection. That would mean putting the R6400 into wifi bridge (repeater) mode. That's a much more complicated move.
    To do that, check the manual for the R6400 and read the section Set Up the Router in Bridge Mode.
    It isn't easy, and might not even work with your anonymous router.
    Your first message said "I would like to set it up to work on the mesh network as a print server".
    Is there any reason why you can't plug the R6400 into the router? It would be there on the network for everything else. It would also be a lot easier to set up and manage.
