phil789
Aug 29, 2016Aspirant
set up router wnr200v3 without internet
At the moment I have a laptop controlling a Behringer X32 sound mixer via wired ethernet. The plan is to use wnr2000v3 to provide wireless access for laptops/phones as well as keeping the wired lap...
- Sep 11, 2016
Success.
Managed to do it by setting another laptop to fixed IP address then plugging it into Wan port .
Now it lets me past the Wan set up screen even with the Wan port dis-connected.
Strange but good to know.
Thanks for your help.
Cheers Phil.
Retired_Member
Aug 29, 2016What if you did setup with internet and then disconnect it? You could even move it to another location, after the initial setup it should give a ****** weather or not it has a WAN connection.
phil789
Sep 02, 2016Aspirant
Thanks for reply Searay
Yes I was holding back on doing as you suggested for fear of messing something up on my home system.
I've since discovered that I would also need a seperate ADSL modem to do this.
Looks like its time to get another router.
Thanks for your help anyway.
Cheers Phil.
- Retired_MemberSep 02, 2016
Not really.... connect wan port to home router lan port....People do this all the time....since you're not going to be using it for Interent It shouldn't matter.
- stha2232Sep 02, 2016Aspirant
Which ip address is used for this router ( http://192.168.1.1 or 192.168.0.1
it might change to 10.0.01 if it sensed another router
