almightyyoshi
Aug 27, 2016Aspirant
Setting IPv6 DNS
I'm trying to specify an IPv6 DNS server in the web interface. When I try to enter the address I want to use, it gives me this error: "The Primary DNS Server is not valid; it has to be a global u...
- Dec 03, 2016
For anyone interested I ended up installing xwrt-vortex (http://xvtx.ru/xwrt/index.htm) which allowed me to set a local ipv6 DNS host and take full advantage of ipv6 DNS filtering for pi-hole (https://pi-hole.net)
ep312
Dec 03, 2016Tutor
Any idea why? Is this an r7000 restriction? I'm attempting to set up a local DNS server but am having no luck due to this error for ipv6
microchip8
Dec 03, 2016Master
not an R7000 restriction, rather sh*tty stock firmware one
- ep312Dec 03, 2016Tutor
Thanks Microchip8 - do you have an alternative firmware you'd recommend? I've used dd-wrt before on Linksys routers, but not sure what plays best with netgear
- microchip8Dec 04, 2016Master
Good. Both XWRT and Tomato are excellent firmwares for the R7000. I used both and stuck with Tomato as it offers some stuff XWRT doesn't yet. Also I had a battery drain problem on XWRT which went away when on Tomato
