Jennings92
Feb 01, 2022Aspirant
Setting Up A Wireless Access Point For The 1st Time - Anything I Should Know?
Hello everyone! This is my 1st post here & I'm hoping someone here can help me out with my questions I have concerning this topic. :) Now after viewing the title, you're probably wondering what ...
michaelkenward
Feb 01, 2022Guru - Experienced User
Jennings92 wrote:
Using a WiFi 6 AX1800 Dual Band Wireless Access Point [WAX204] I got 6 months ago along with the router, but I haven't got around to using it just yet.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. In thos case you asked about the WAX204, which is a Business WiFi 6 AX1800 Access Point.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
or
Business Wireless - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Jennings92
I should have mentioned that I looked up the specifications for the access point, but didn't manage to find much. Hopefully, that's where helpful communties like this 1 come into play. BTW, I also forgot to mention that for the router, my support has run out & I can't afford any or a warranty. Still, regarding the access point, I didn't really know it was for business use when I got it; I was just trying to find something compatible that would work well together. I'm hoping someone here can answer the technical questions I have since that's what communities & forums are for anyway. :)
- michaelkenwardFeb 01, 2022Guru - Experienced User
Jennings92
I should have mentioned that I looked up the specifications for the access point, but didn't manage to find much.What details do you need that are not in the data sheet or the manual?
See previous link for where to get those.
I didn't really know it was for business use when I got itThat's just marketing guff that let's them add to the price. Sadly, it also means that they probably don't sell that many and that there aren't many users here who know how it works.
I just mentioned it so that you can find the place where they talk about that particular gadget. This place is as good as any to get help. Ignore anyone who tries to tell you otherwise. They just want a tidy life.
