tomas041857
Feb 17, 2019Initiate
Setting up my R6400 in bridge mode.
I am trying to get my R6400 router in the bridge mode by following the directions of the manual and it does not seem to work. Is there something else that needs to be done before I go to the bridge m...
- Feb 18, 2019Okay I have it figured out. It was a stupid thing like putting in the right password for the router.
antinode
Feb 17, 2019Guru
> I am trying to get my R6400 router [...]
"R6400"? "R6400v2"? Look at the product label. Firmware version?
> [...] in the bridge mode by following the directions of the manual
Which "the directions", in which "the manual"?
"trying"? What, exactly, did you do?
> [...] and it does not seem to work.
"seem"? How, exactly, did you reach this conclusion?
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] Is there something else that needs to be done [...]
Other than what?
> [...] I do know that the ISP router modum [...]
What is your "the ISP router [modem]" (MOdulator/DEModulator)?
> [...] has the same IP address as the R6400.
The R6400 should get a different LAN IP address when you configure it
in bridge mode. (What else do you "know" that isn't so?)
Does your (unspecified) "the ISP router [modem]" have something like
an "Attached Devices" or "DHCP Clients" report where the R6400-as-bridge
might be expected to appear? Does it appear there?
