ChrisNS's avatar
ChrisNS
Setting up old Netgear router (N150 - WNR1000v3) as wireless access point?
I setup the router as an access point and noticed in the wireless settings it still had Enable SSID Broadcast enabled and it's own default SSID name and password. My question is, since it's being use...
  • wcalifas831's avatar
    Apr 09, 2017
    you don't need to disable broadcast SSID. You need to disable dhcp, and set a parameter of ips that the access point can give out to devices that is different than the router that you're attaching it to that way they don't give out the same IPs to other devices.
