Hotgogs
May 06, 2021Follower
Setup help ac750
Trying to set up my 2nd range extender. I returned the first because I thought it wasn’t working but this one is the same. After connecting it to the router any connected device has no internet. What ...
May 06, 2021Guru - Experienced User
What router are you connecting it to?
Are you setting it up using wps or the installation assistant?
Firmware on the extender?
