Beth007
Nov 04, 2021Initiate
Setup help needed
EQUIP: Arris Cable Box, Netgear Nighthawk AC1750 iMac Desktop IOS 10.15.7 Powered the AC750 extender in wall outlet near router and cable box. Green light on. Try to connect holding WPS buttons ...
- Nov 04, 2021
The wps might have worked and thats why the _ext asked for a password.
Try the routers wifi passwrod.
If that doesn't work, try factory resetting the extender (push and hold reset for 7-15 seconds while powered on).
then try to connect to the _ext and going through setup assistant.
Nov 04, 2021Guru - Experienced User
