Ob11
Nov 26, 2020Aspirant
Setup N300
Hello, I am trying to connect my N300 router. The connection is fibre to the cabinet and then phone line to the house (essentially gets around 30mbps as opposed to 16mbps from isp - when it’s worki...
antinode
Nov 26, 2020Guru
> Model: DGND3300v1|N300 Wireless Dual Band ADSL2+ Modem Router|EOL
Is that accurate? DGND3300[v1] or DGND3300v2? Look for "Model" on
the product label. Firmware version?
> [...] have walked through settings together but no connection is
> detected through the n300. [...]
I must have been distracted during that conversation. Care to review
the important parts?
> [...] Does this router support the connection (ie part fibre but
> normal line in the house). [...]
It's an ADSL2+ modem+router. How much should I know about your "ee"
service?
> [...] ee advice says yes. [...]
They should know.
> [...] Is there an update required on the router that I have to
> complete to fix the issue perhaps [...]
Not very likely.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads. (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".) Find the
kit(s). What's available? What's newer than your current firmware
version?
and look for Documentation. Get the Manuals. Read. Look for the LED
descriptions and "Troubleshoot". Feel free to reveal exactly what
you're doing, and what happens when you do it.
