DrOrb2
Apr 29, 2021Follower
Setup Trouble
I have: 3x Ethernet Cables (OK) 1x iPhone WiFi (OK) 1x iPhone WiFi can't connect 1x Laptop WiFi can't connect (msg: NETGEAR05 No internet secured) Is there a router limit of 4 connections? ...
antinode
Apr 29, 2021Guru
> I have:
Connected to what?
> 1x iPhone WiFi (OK)
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
With my weak psychic powers, I can't see how you configured your
(unspecified) router, or to what you connected it. Has it a model
number? Look for "Model" on the product label.
No. Do your wireless devices all use the same radio band?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Beyond the basic set-up instructions, look for the LED descriptions and
"Troubleshoot".
