relayer23
Jun 22, 2021Tutor
Severe download speed drop
Hope someone can help here... Router was working fine until last week, when my download speed severely dropped: from 229.9Mbps to approx 30.2Mbps. I checked my cable on a multimeter; it's fine. ...
relayer23
Jun 22, 2021Tutor
1. When something's gimping, I like to do everything possible before flashing firmware; old habit from when that could be disasterous. Much better these days.
> Yup, this is all hardwired with Cat6.
Now, #2... going over & over every single setting in both Basic & Advanced, I got to:
Advanced > Setup > QoS Setup:
Enable Upstream QoS (Optimized for gaming) - checked ((I never use QoS))
Uplink Bandwidth > was at Maximum 512 KBPS<<<<<
See the problem here? Somehow (we had hellish lightning storms last week/don't know?) QoS reset itself to ON. It took me three looks at it to see > Kbps!<
Switched it back to Mbps and I'm back to average 233Mbps download.
Sorry to stir the pot on this when it's an old router (it works GREAT actually) but never imagined a flipped bit on QoS/Uplink Bandwidth :O
Thanks for the swift reply! Maybe this can help others who have this weird problem.
Jun 23, 2021Guru - Experienced User
Glad you got it working.
Might be getting to be that time to check into a router update with the speeds you have available.
the move from N750 to a AC or AX device would enhance your wireless capabilities quite a bit.
- relayer23Jun 23, 2021Tutor
I live in a small apartment and my wifi needs are few; just Roku and a phone that I only use as... a phone :D
I think I figured out the answer to my problem - as mentioned, we had some wild weather last week and we had a power-out. So I'm thinking the router went down and when the power came back, it reset to factory specs, including the never-used QoS section...
*shrug* however it happened, it's all good now.
Now if I could just get it to take another username besides "admin"... :)
- michaelkenwardJun 24, 2021Guru - Experienced User
That's where timing can come into the picture. If you have a modem in front of the router, the modem can take so long to connect that the router times out before it can connect.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Don't worry about it. I have never seen reports here of people breaking in with that username.
The only way in is through the local network. Given your minimal use, there isn't likely to be anyone outside the family or visiting wifi users trying to get at your router, especially if it has a decent password.
People can't get in from the outside world without going through Anywhere Access, which require a bunch of usernames and passwords to set up and get on.
