molaver
Nov 30, 2021Tutor
Should I do a factory reset?
I recently changed internet providers from Comcast at 75mbps to 1 Gig 5G fiber optic. Wifi properties of the Netgear router (shown on my laptop) list the link speeds at 866 receive and 433 transmit....
- Nov 30, 2021
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/product/R6220.aspx
Its a great resource to start with for finding those settings.You can access the routers setting through your browser pretty easily.
Or you could just factory reset it and start back at square 1. Never a bad idea when switching isp's or changing speed.
molaver
Nov 30, 2021Tutor
Thank you for the quick reply. Not sure where to look for qos, access control, traffic monitoring, parental controls. I went to the administration page of my router and only found a traffic metering setting which was set to off. Are the settings you mentioned found on the router or the laptop? After establishing these things, I can then do the hard wire from the router to the laptop and report the results. The modem (ONT) I am using was supplied by the ISP which they remotely tested and claimed is functioning properly at 1 gig speed. Although the provider's tech support only addresses issues with their hardware, they did mention that there might be an issue with a firewall. I poked around and found firewall settings but nothing that looked like it pertained to the router or internet settings so I left everything alone. I apologize for needing a bit (or a lot) of hand holding...wifi/networking issues are not my strong point.
Nov 30, 2021Guru - Experienced User
