jason4427
Aug 29, 2015Follower
Should I update my WNDR3400v3 to the 1.0.0.48 Firmware?
I see there is a 1.0.0.48 firmware update on the Netgear website, but the check on the router software says I'm up to date even though I'm on 1.0.0.46. Should I update?
Personally, I don't upate because there is new one out.
If you have a valid reason of course but if things are
running fine, why bother? I don't buy the idea of updating
because there is new one. If you think you must try, then
you can do it manually.
1 Reply
- VE6CGXMaster
