JoeHag
Nov 23, 2020Tutor
Should RBS40 appear under Your Products in android?
All devices and software are at current code. In the Orbi app on android, under the HOUSE, I select the House (Your Products). It shows RBR50 - which is what I bought first. Since then, about a week...
michaelkenward
Nov 24, 2020Guru - Experienced User
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
or
