johnjon's avatar
johnjon
Follower
May 21, 2017
Sign into router
What's the difference between signing into netgear 18-5G and netgear18 ?
Thanks
John
  • The the first, by convention, is a 5 GHz Wi-Fi signal, while the other is a 2.4 GHz signal.  5 GHz Wi-Fi is often faster due to higher bandwidth and fewer users.  It has slightly less range but it often makes up for that with faster speeds.  Clients must also support 5 GHz Wi-Fi.  This is often known as "dual-band" support.
1 Reply
