CromsMT
Nov 01, 2015Aspirant
Signal Strengths
Signal drops to almost nothing. Knocks out Netflix. Just started and we note Traffic meter shows a normal month of dowlads is 440 and then last month it was 71,647 and yesterday was 680 just for the ...
- Nov 03, 2015
I suggest that you try to change channel first on the router by accessing the admin page.
Or if you happen to have the NETGEAR Genie installed, you may see the best available channel used.
As an example, I can use channel 4 since there's only 1 connected at it. You might be wondering channels 12 and 13, these channels are only available in some countries.
But if you're in the US, your available channels to be used will be from 1-11.
Once you have seen the best channel to use, you may go ahead and change the channel manually by clicking the button to modify the settings.
ElaineM
Nov 02, 2015NETGEAR Employee Retired
Welcome to the community, CromsMT
What's the exact model number and version of your NETGEAR device?
Which signal you're connecting to (2.4Ghz or the 5Ghz)?
How far is the wireless device from the wireless router?
Did you try changing channel on the router?
How about relocating the router?
Make sure that there are no other device that may cause interference such as cordless phones, microwave ovens, baby monitors, thich walls and the likes.
When did the problem start?
Do you have the latest firmware version installed on the router?
Have you tried factory reset?
Looking forward to your response.
