CromsMT's avatar
CromsMT
Signal Strengths
Signal drops to almost nothing. Knocks out Netflix. Just started and we note Traffic meter shows a normal month of dowlads is 440 and then last month it was 71,647 and yesterday was 680 just for the ...
  • ElaineM's avatar
    ElaineM
    Nov 03, 2015
    I suggest that you try to change channel first on the router by accessing the admin page.
    Or if you happen to have the NETGEAR Genie installed, you may see the best available channel used.
    As an example, I can use channel 4 since there's only 1 connected at it. You might be wondering channels 12 and 13, these channels are only available in some countries.
    But if you're in the US, your available channels to be used will be from 1-11.
    Once you have seen the best channel to use, you may go ahead and change the channel manually by clicking the button to modify the settings.
