Giovanni04
Nov 01, 2021Aspirant
Simultaneous dual band portable router
Good morning everyone, I'm looking for a portable router that allows simoultaneous dual band, but I can't find anything on the internet. I hope I'm in the right section. Thanks for your answer Giov...
Giovanni04
Thank you that was quick!
I just bought a TP-Link Archer MR600 from amazon, but hasn't arrived yet. I'm thinking if there is either a portable router or hotspot, with the same performance, but with a built-in battery and possibly smaller. Actually I'm not sure if MR600 supports simultaneous dual-band, how can we know that?
I'm going to use it with a 4G sim card to work on my laptop at 2.4ghz, which doesn't support 5ghz, and play online on my ps4 at 5ghz.
Nov 01, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
- Giovanni04Nov 01, 2021Aspirant
Oh I didn't notice it, thank you
- FURRYe38Nov 01, 2021Guru - Experienced User
đ
