Lancelotdb
Aug 07, 2023Tutor
[Site blocked: tlu.dl.delivery.mp.microsoft.com] from source 192.168.1.23
Hello, The logs regularly indicate that the router is blocking a Microsoft update. After several requests, the router goes into protection mode and the Internet is no longer available. How can I f...
- Aug 09, 2023
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
Lancelotdb
Aug 07, 2023Tutor
Thank you for your help.
I have the R6400v2 router firmware V1.0.4.128_10.0.104.
I have the Nighthawk application but I can't connect to it from my phone using the login and password which works from my PC with the url http://www.routerlogin.net/start.htm
michaelkenward
Aug 08, 2023Guru - Experienced User
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
