Lancelotdb
Aug 07, 2023Tutor
[Site blocked: tlu.dl.delivery.mp.microsoft.com] from source 192.168.1.23
Hello, The logs regularly indicate that the router is blocking a Microsoft update. After several requests, the router goes into protection mode and the Internet is no longer available. How can I f...
- Aug 31, 2017
Hello Ziadturk
I checked the system and there is all of this engagement was recorded so yes that was Netgear tech support I was not aware they did this but you should be fine.
DarrenM
Lancelotdb
Aug 09, 2023Tutor
Thanks for your reply.
Indeed, my provider use a modem technicolor. Behind there is a Huawei AR161 G-L Router and then my routeur netgear.
Does it help?
Kind regards
Lancelot
Aug 09, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
- LancelotdbAug 21, 2023Tutor
Hi
Many thanks for advices.
I am busy with my provider to fix it with your solutions
Kind regards
