Asberry
Oct 08, 2015Aspirant
?sloooooooooow wifi?
Netgear N600. With ethernet wired downloading at 66 Mbps. With wifi, downloading as follows: Last Result: Download Speed: 0.8 Mbps (0.1 MB/sec transfer rate) Upload Speed: 3.54 Mbps (0.44 ...
- Oct 26, 2015
Recently moved about 80 miles and just got recconnected with same charter service, but new equipment. At this point I have run the speed test about four times and am running consistently in the upper 30's Mbps. Hopefully that will continue. If not, I will be back asking questions again. Thank you very much for taking the time to reply to my query.
Babylon5
Oct 09, 2015NETGEAR Employee Retired
What is the model number of the router e.g. WNDR3700?
Is it a router only i.e. no modem, or does it include a modem (DSL or Cable)?
Can you post details of the Wireless device, manufacturer / model number?
Have you tried temporarily disabling wireless encryption?
Do you have WMM enabled?
Does this issue appear at all wireless computers?
- AsberryOct 26, 2015Aspirant
- AsberryNov 17, 2015Aspirant
So, I just followed the instructions for upgrading firmware. I clicked the link. When I click upload it tells me to add *chk to the file name. I add it. It gives same message. I cannot change the name where it is filed to include *. Are there any upgrades out there that are usable, or are they all bogus?
- doraemonNov 17, 2015Prodigy
Did you download the correct firmware for your router model version?
There are different router model versions so you may want to double check on that.
The router model version can be located after the router model number.
If you don't see v2, v3 or whatsoever then your device is just simply version 1.
