d1gster
Nov 17, 2020Aspirant
Slow ethernet and wifi speeds over sat
I have the xfinity gigabit speed plan, but from satellite in my room i am only receiving about 200mbps on wifi AND ethernet. Using the Arris t25 modem, my room is about 35 feet from the router. ...
Nov 18, 2020Guru - Experienced User
So thats the speed you're getting from the satellite.
What speeds do you get from the router? that's the key.
Satellites speeds are going to be less because its transmitted over the wireless backhaul. And the RBK20 series uses the 866mbps link speed backhaul. of that 2 things.
1. link speed is not the same as actual speed.
2. distance/obstruction is going to drop the speeds from optimal as well.
- d1gsterNov 18, 2020Aspirant
xfinity test: my mac says 600mbps on wifi right next to my router, my phone says 200mbps on wifi next to my router
google test: my mac says 256mbps on wifi next to my router, my phone says 150mbps on wifi next to my router
orbi app: 789mbps (from modem i assume)
i have the orbi connected to the arris t25 modem using a cat 5e cable, and i have a cat 8 cable i can switch to.
the orbi is connected to the wall and the modem is connected to a power strip
- plemansNov 18, 2020Guru - Experienced User
200mbps over wifi isn't an unexpected result. the Orbi supports 866mbps link rate (again, not throughput) for both the backhaul and the fronthaul. And usually wifi speeds are device limited. meaning the devices is the bottleneck.
did you test hardwired speeds on the modem ,router, and then satellites?
- d1gsterDec 04, 2020Aspirant
sorry, i was waiting for my ethernet adapter to come so I could reply. I am also experiencing drops in service where the satellites will turn pink for about 5 minutes. I am currently contacting xfinity about slow speeds on my end.
Modem - XFINITY 117/34 & GOOGLE 91/24
Router - XFINITY 94/40 & GOOGLE 93/36
Satellite 1 - XFINITY 86/35 & GOOGLE 83/35
Satellite 2 - XFINITY 97/33 & GOOGLE 91/35
