TaterSalid's avatar
TaterSalid
Virtuoso
Dec 07, 2018
Slow Ethernet with WNR3500Lv2
After reading this if you think I am crazy, well that is OK.   For nearly 2 months I have fought with a throughput issue. I have a 3+1 (4) router network. Link if you are interested: https://ww...
  • TaterSalid's avatar
    TaterSalid
    Dec 08, 2018
    michaelkenward wrote:
    TaterSalid wrote:
    The other two routers are irrelevant to this topic.
    That depends on how they are configured.
    Michael, I resorted to a standard configuration with only one router in troubleshooting this. I added that line to reduce clutter and confusion. The only reason multiple routers ware mentioned is that they were involved in the solution. Had I not had another Gbit router I would still be troubleshooting.
