Sukhjeevan
Nov 22, 2020Aspirant
Slow internet speed issue with NETGEAR N600
Hi All
I have NETGEAR N600 Cable Modem Router (C3700). My internet speed is only around 40 Mbps even I do have 200 Mbps xfnility internet plan. xfinity support asked me to contact Wi-Fi device manufacture company. Any suggestion what can I do to get expected speed.
https://www.amazon.com/gp/product/B00IF0JAYE
Thank you
> [...] My internet speed is only around 40 Mbps [...]
Measured how? Using what for a client device, connected how? Wired?
Wireless, 5GHz? Wireless, 2.4GHz?> [...] what can I do to get expected speed.
What is your "expected speed"?
Why blame the C3700 rather than your (unspecified) client device?
Does your (unspecified) client device get higher speeds in some other
environment?- SukhjeevanAspirant
I'm using HP laptop Elitebook and connected internet via Wi-Fi connection.
Tested with Network Band at 2.4 GHz
- Disconnect from office VPN
- xfinity speed test: ~50 Mbps
- speedtest.net speed test: ~10 Mbps
- Connect from office VPN
- xfinity speed test: 0 Mbps
Tested with Network Band at 5 GHz
- xfinity speed test: ~120 Mbps
- speedtest.net speed test: ~20 Mbps
- xfinity speed test: ~0 Mbps
Speed is little better now with 5 GHz but only while disconnected from office VPN. I cannot work while disconnected from office VPN so not much helpful.
In office I get enough speed and don't see any disturbance while attending online meetings.
Is there any other setting I can change in modem router to get higher speed? If not any suggestion for good modem router.
Thank you
