ramdino
Dec 17, 2022Tutor
Slow internet speeds with point to point air bridge
I have 2 netgear routers with 2 M5 dish created a point to point air bridge from my house to a shop thru trees. My speeds have always been 50 mbps until recently they have dropped to 9Mbps. I can see...
- Dec 17, 2022
Final update. I'm good!!. After updating the firmware on both dish and tweaking the dish alignment my speeds are back to 40-50 mbps. Not sure why it was good one day and slow the next. But is all good for now.
Dec 17, 2022Guru - Experienced User
1. yes a loose wire could cause issues
2. not sure what the M5 point to point system is. Do you have a better model number?
3. did you test the speeds at the point to point system prior to the router connecting? If the first router has full speed and you don't at the end of the point to point system, its likely to be the point to point system. Either its connection between them, the wires connecting devices, or the devices themselves.
