Andycivil
Nov 14, 2020Follower
Slow orbit broad cast speeds
I have reallly fast speeds coining into my AT & T modem, but the speed coming out of my ORBI WiFi is much slower. Can someone help? I have the router WiFi broadcast turned off. I've attached a ...
Nov 14, 2020Guru - Experienced User
A couple things.
1. pictures have to be approved by a moderator. it can take a while. If you want that info viewed, attach it as a file. Or just type the numbers out. we'll believe you.
2. What att gateway do you have? Most have integrated routers and cause a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
Turning off the wifi doesn't shut off the routing capabilities.
3. how are you speedtesting? over wifi or hardwired? make sure to test hardwired.
