REO45
Apr 18, 2022Aspirant
Slow speed on AC1750 2.4 GHZ
I have 100 Mbps service from Xfinity. I have started to notice that my speeds (using Ookla) are in the 10 Mbps range on the 2.4 GHz band and 100+ on the 5 GHz band. I see consistent results on both...
- Apr 18, 2022
You might be able to get better speeds. 2.4ghz is a much slower network than 5ghz but it broadcasts further and through more materials.
To start off with, try changing what channels you're on for the 2.4ghz. try 1-6-11. See which one works better.i'd also try several devices.
REO45
Hi,
I tried all three channels with similar results, all three in the 40+ mps range which is much better. Will monitor now for awhile to see it it continues. Thanks for the help.
Apr 18, 2022Guru - Experienced User
40mbps is about what you can expect out of 2.4ghz. Like I said, its not a high performing band but has more range/penetration power.
