wifiblues
Jul 31, 2021Luminary
Slow speed post firmware v4.3
Hi. Just upgraded firmware on the rbk752 to the v4.3. It slowed down my connection. Prior firmware much faster. Question. Is WMM changed with firmware change? Thanks. Wifiblues.
OculusSinister
Jul 31, 2021Aspirant
Having the same problem with slow speeds since the recent firmware update and I’m now unable to connect to the router through the app.
- wifibluesJul 31, 2021LuminaryI sent a note to netgear help. Thinking of a factory reset. Hope that brings the speed back.
- michaelkenwardAug 01, 2021Guru - Experienced User
OculusSinister wrote:
Having the same problem with slow speeds since the recent firmware update and I’m now unable to connect to the router through the app.You replied to a question about the Orbi RBK752. Your footer says you have the R7900P, a very different animal. Different apps even.
Questions about the R7900P are best dealt with in the appropriate section:
- wifibluesAug 01, 2021LuminaryTyping this from my phone. Using the AX4200 RBK 752. Latest firmware slowed speeds down from over 900 to 600. Besides a factory reset, any solutions why or what the latest firmware changed?
wifiblues wrote:
Besides a factory reset, any solutions why or what the latest firmware changed?Visit the support pages:
Support | NETGEAR
Feed in your model number. That page will have links to firmware.
Check the release notes for the latest firmware to see what has changed.Be warned, those notes can be skimpy. They will not reveal details of any security updates that they set out to fix.
