tomsnett
Dec 25, 2022Follower
Slow Speed
Installed new R6120 router. Speed from my modem through Ethernet connection is 350 Mbps. Through the router it's 95 Mbps on 2.4 GHZ, 5G and Ethernet. My previous router was 350 Mbps. Any idea why? ...
michaelkenward
Dec 26, 2022Guru - Experienced User
Put simply, you bought the wrong router.
The top speed the R6120 can deliver is 100 Mbps. That is the specification for its WAN and LAN ports, the sockets on the back that connect to the Internet and the things on your network.
The R6120 is one of a small number of Netgear routers with 100 Mbps Ethernet. All the others offer at least gigabit.
Netgear should take these devices off the market. It is amazing that they still exist more than a decade after gigabit became the standard.
Return your router and get something that supports your Internet speed.
