2TMW
Nov 24, 2020Follower
slow speeds
I am using a 5 or 6 year old EX6100 (not a v2) in my home as an access point. It is connected by ethernet to a router (Xfinity supplied). The wireless speed six feet from the router are 300+ MBS by O...
Nov 24, 2020Guru - Experienced User
The EX6100 is a single antenna 5ghz solution. Meaning its max link speed (not throughput) is going to be 433mbps. the general rule of thumb is max throughput under optimal conditions is roughly 55-65% of what the link speed is.
So rough maximum would be 240-280mbps. Under optimal conditions.
What link speed do you have?
How are you testing speeds?
You said its hardwired into the router and the extender is running in access point mode?
Make sure its running in access point mode. In extender mode, you'll lose 50% of your throuhgput.
have you tried factory resetting and reinstalling it using the installation assistant in access point mode? if you set it up using wps, it might be running in extender mode and that can cause that 50% throughput drop.
