Brandon_P
Apr 02, 2020Tutor
Slow wfi speed
I have a WNDR3400v3 router and CMD31T modem. My xfinity service is 100 mbps, however, I only get 20-25 mbps on wireless in the same room. If I connect ethernet cable to the router I can get ~60 mbp...
- Apr 02, 2020
Wifi speeds are down to the wifi clients you are using. You don't say what they are. Or the firmware version on your router.
Your WNDR3400v3 router is old technology. The original dates back to 2010.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN on the WNDR3400v3 support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. It is slower than the LAN port on your modem. That may be restricting your speeds.
Brandon_P
Apr 02, 2020Tutor
I replaced my WNDR3400 with a R6400. Now I'm getting much faster speed, at least according to test on nighthawk app. I didn't replace the modem.
michaelkenward
Apr 03, 2020Guru - Experienced User
No need. Your original was capable enough of handling your Internet speed and handled the link to the router.
Modems are pretty basic devices in my experience. They either work or don't work. The router does the hard work.
You have also shown the value of having a separate router and modem. You can just upgrade the bit that is the weak link.
